need help please
642 Views 2 Replies 2 Participants Last post by  lewisbeaven90
Hi all I've just installed a decent 8000k hid kit but 1 bulb seems brighter than the other anyone have any ideas I've been told it may just need aligning. Is this true?? Thanks x
:err: 8000K? you get more light the closer to 5000K you are, but each to their own,
if one is brighter, have you tried swapping them over? if for example it's drivers side that's brightest, and still drivers side once swapped, then it will be alignment.
if the bright side swaps over to the passenger side, then it'll be the bulb itself.
I like the 8000k because they are slightly more blue.
Ok thanks for your help i will try that this evening.
