Good morning everyone,
I am new here, but I just bought a 2002 MG TF 120, with 130,000km on the clock. I am currently having a Roadworthy done on it, but our mechanic has picked up on some other concerning and disappointing issues. He thinks he can hear a 'slight' knocking sound in the engine (only when the car is hoisted) and a rattle 'in the gearbox'. I'm just wondering what these things could be, and if anyone has some advice. Could the rattle possibly be the external drive plate?
Hoping the knock is not big end bearings!
Thanks in advance.
Cheerio,
Caleb
I had a knocking noise come from my 2003 TF. I could only hear it at idle really, from the outside, engine noise drowned it out at higher rpm. It sounded bottom end knocking to me so I was convinced it was not going to end well. It sort of got quieter then louder over periods of ten seconds or so.
Anyway, after a year of worrying I did some things to try and diagnose it. I drained the oil and changed the oil filter. The old filter had no visible metal bits in the filter and there was no swirly sheen of metallic dust visible in the oil. Knocking means a worn big end/little end bearing, so where was all the worn bearing metal if that was the case?
I refilled it with oil. The knocking was still there. I poured STP oil treatment into the oil filler whilst it was running - I couldn't detect any difference in the knocking. STP is very gloopy stuff indeed, I was expecting it to quiet a big end knock.
The knocking seemed slightly louder on the driver's side. I bought a mechanic's stethoscope and started prodding the probe onto likely looking places whilst the engine was running - the block, manifolds, the sump etc. Guess where the noise got really loud - the plastic timing belt cover. When the head gasket went years ago it ended up in a dodgy garage and the car had a slight wiff of hot rubber about if for sometime after. I think they refitted the cover improperly but it's hard to see.
I can't tell you the best way to diagnose knocking but those are the things I did. I believe worn big ends will make noise that doesn't disappear at high rpm and there may be a change in volume with with loading, but you'll have to read up on diagnosing worn big ends to get a better idea if there's a killer test you can use. The stethoscope really works, you might give that a try.
