1 - 9 of 9 Posts
ok....so of late i've noticed that there is a "puff of smoke" when i start up in the morning. I pulled the plugs and found plugs two and three to be soaked with oil (my poor platinums..). And this morning, the car has developed a miss
does this mean that my valve seals are gone? or is there a deeper and darker problem that needs addressing?
Could be valve stem seals as you mention, especially if there isn't a lot of oil consumption. Of course it could be HGF or worn/broken piston rings if the oil is disappearing fast and it smokes all the time.
When you say soaked by oil how bad are they?
Of course if you've got a dead plug/HT lead then the smoke could be unburnt fuel and it would also account for the misfire too.
i confirmed that its the valve seals......loving the "misfire" sound though...sounds like my old MkII Escort with Piper Cams......(grins)..oh how i miss the days of tail waggin....
Discussion Starter #5
87K kms.... have had the HGF done. had the timing belt changed. What i've recently have done is run 2.5 inch exhuast from the down pipe straight out and i run a Hyabusha back box. Idont know if the exhaust change has anything to do with it...
(see pic..)
Administrator
More likely to be a poorly sealing valve than the valve stem seal at a guess.
Bit of grinding paste and elbow grease.
1 - 9 of 9 Posts
