My 2003 TF 1.8 suffers from a random misfire at idle. It doesn't appear to occur at higher rpm or at load. It's not a big deal and the engine doesn't 'stumble' at idle, just this little misfire anywhere from twice per second up to maybe once in every few seconds at random when idling.
When I modified the lower engine brace arm (that's probably the wrong name) to use poly bushes I could feel the misfires through the back of my seat and it was a bit annoying to be honest so I went back to a lower brace arm with rubber bushes.
I just thought of the misfire as 'one of those things' for a long time but I now want to eliminate it as I think it must be related to some sort of fault.
I did change the HT leads (not the coil packs) a while ago but it still misfires. I'm thinking it's almost certainly to do with the spark but would be interested if anyone else has ever had this problem and what the solution was. I wonder if the fact it only seems to misfire at idle is some sort of clue?
