I fitted a new clutch mater cylinder today and changed the rubbers in the slave cylinder, while the cover was off I took the revers switch out and added a fibber washer, all working as it should now, thanks for the advice it was spot on, now I have to adjust my head lights. one is all over the place, I have tried to adjust it previously without success, I'm going to remove the bulb and re-fit it then adjust the light, fingers crossed.
Other than that the car is great, I bought this in 2017 for ÂŁ650, and spent quite a bit getting the engine upgraded to N series spec, the full hit Oil rail, high tensile head bolts and a Payen multi layer head gasket, the cylinders were checked for level and found to be all correct. The head gasket wasn't gone but I wanted to make sure it was reliable.
Got to say I have been surprised how good the car has been, not had any real problems just the usual maintenance you get with any car, did 1200 miles around Scotland and back to Wales in all sorts of weather, went great all the time.
