1 - 10 of 10 Posts
Hi Guys,
just wondered if anyone has had a TF rear suspension failure. Driving around and suddenly handling was different and when I went round a corner I could hear what I think was the tyre rubbing. After checking I see that the l/h rear is a lot lower than the r/h (just like the F does but its easy to blow up).
I cannot check it out until Monday and so I thought I would ask on here for some tips.
Many thanks in advance
Clive
In the Garage
MG TF
Complete suspension failure isn't a common problem on the TF however they getting to an age were it is possible that components are starting to fail, I would also go along with it being a broken spring. It would be interesting to know what it is so that we can all keep an eye out on our own cars.
'10 TF135
I've never heard of broken TF springs but I understand the bottom damper bolt was an area of TF weakness.
The later post '05 TFs had a square-sectioned 'dog bolt' upgrade to make them a bit stronger, front and rear.
Apparently Ford Transit suspension bolts were/are the same size as the pre-'06s but were a heavier-duty upgrade. I found this out after the front o/s lower damper bolt broke on my ex-'05 TF when in the care of it's previous owner and the garage put the repair details on the invoice...
Yes, as per Chris T, please keep us posted.
Could be wheel bearing, one of my TF's dropped when the bearing collapsed.
If it does turn out to be a broken spring, make sure you replace the other side too. This will help to ensure even handling, plus there is a chance it might be going the same way as the one that (might) have already gone.
Good luck.
Discussion Starter · #10 ·
Many thanks to all who answered with helpful comments, as usual the help was exceptional.
Many Many Thanks
1 - 10 of 10 Posts
