1 - 2 of 2 Posts
Hi,
I have to fix the oil leak between the gearbox and the engine (I think it will be a seal - LUF000050). By the way, I want to replace all the remaining seals. I also have sweaty seals on the differential. However, I do not know which ones to order, as there are two types depending on the serial number of the gearbox:
TRX100100 - Seal differential - RH to: C4BP-3759
UNG100060 - Seal differential - RH from: C4BP- 3760
My gearbox number is: C4BP-2048715.
Should I consider the last 4 digits of the gearbox number and that means UNG100060 will be suitable?
best regards
As 2048715 is a higher serial number than 3760, I would say you are correct in thinking that UNG100060 is the right one.
1 - 2 of 2 Posts
