Hi,
I have to fix the oil leak between the gearbox and the engine (I think it will be a seal - LUF000050). By the way, I want to replace all the remaining seals. I also have sweaty seals on the differential. However, I do not know which ones to order, as there are two types depending on the serial number of the gearbox:
TRX100100 - Seal differential - RH to: C4BP-3759
UNG100060 - Seal differential - RH from: C4BP- 3760
My gearbox number is: C4BP-2048715.
Should I consider the last 4 digits of the gearbox number and that means UNG100060 will be suitable?
best regards
&y
Hi,
best regards
&y
I checked my MG Rover Electronic Parts App and I see the problem; even on that, it is not clear. If you give me your VIN number, I can check as the App will only show the relevant parts' codes for your car.
Per your VIN, you have MG, MGF and MG TF, Class 5, 2 door, Cabriolet, Normal Aspiration, 16V, MPi, 135PS, Petrol, DOHC, 1800 cc, K Series, 5 Speed, C4, LHD, Manual, Model Year: 2004.
You need the UNG100060 Seal differential - RH
