Thanks Steve!.SHARKYMGF said:Had a quick look on Rave. Looks like you have to unplug it and then lever it out at one end (from the outside) using 'a round edged flat blade, bent to 20degs at the tip'. This should release it from the clips.
TBO I'm not sure if it uses LEDs or bulbs.
