1 - 8 of 8 Posts
mgf
Hi,
There is no plug for a heated window in my 2003 MGTF, I have looked carefully in the right spot!
Around the correct area though are two wires where something has been cut off. There's a black wire and a black/green wire with nothing attached. Are these the correct colours of wire for a rear window. I believe it's had a heated window in the past as it has the switch and relay already fitted. I can add some spade connectors and connect it but would like an idea if they're the correct wires first.
mgf
All done, tested with multimeter to confirm and now working correctly with switch. I will look out for a connector second hand but happy to use spade connectors to get it working ready for the cold weather
1 - 8 of 8 Posts
