In my 2000 MGF, the transmission dipstick has broken. I need to know the correct length for this dipstick so I can modify another to fit?
Hi, I had the same problem and did not get a clear answer from anyone. But, i have another stepspeed car and the dip stick length from tip to the underside of the stop flange is 427mm. good luck with your replacement one, I repaired mine with a jubilee clip. Allan
Thank you Allan for that information. It has shown me that the ceramic handle has shifted up the shaft about 8mm, giving me a false reading on the stick. I can now cut a longer stick to the correct measurement. Rod
