I had a good day yesterday, all 6 gears , all in the right place.!
I couldn't find a pin or something appropriate , so……..I made one .
I got a drill bit ( don't know what exact size it is ) and rustled around in my box of left over bolts accumulated over many years ….lol
I found a long bolt that was so close to the drill size i had.
Drilled out the hole on the selector shaft, only taking out the very minimum and also the bell crank,
I cut the shank off the bolt and created a pin just the right size and tapped that in thru.
I was a firm fit so shouldnt work loose, plus put the pin securing clip from the original set up and now
it is solid on the shaft, no movement at all !!
Then i was able to begin the process or finding the gears.
Strangly, the horizonal joint couldnt go back in far enough to engage 2-4-R
So i had to cut about 5mm of its stem to enable more movement.
This was enough to make the missing gears come to life once more.
A quick test drive on a sunny day with the top down and 26d Celsius temp .
All went well…….Job done.
