mgf
Hi Ive Just Bought A 51 Plate 1.6 Mgf And I Notice When I First Start It Up The Revs Go Up Then The Needle Shakes And It Seems To Stabalise, Also When Driving Up A Hill In First It Will Lose Nearly All Power, Then Once I Brake And Put The Clutch Down Its Fine, Only Does This When Engine Cold,, Any Ideas, Hope I Havent Bought A Duff One.
NOT SURE IF THIS IS RIGHT PLACE FOR THREAD SO PASTED ON ASK THE GURUS AS WELL
Welcome to the Forum JT. This is a good place to ask such questions about your MGF.
Maybe you could try to reset the throttle settings. Switch the key to the first position, I think, and pump the accelerator to the floor 5 times. Switch off, switch it back on and restart the engine. See how it goes.
Also, could you try and use proper Sentence case next time? It makes posts easier to read.
