1 - 5 of 5 Posts
mgf
Hi Ive Just Bought A 51 Plate 1.6 Mgf And I Notice When I First Start It Up The Revs Go Up Then The Needle Shakes And It Seems To Stabalise, Also When Driving Up A Hill In First It Will Lose Nearly All Power, Then Once I Brake And Put The Clutch Down Its Fine, Only Does This When Engine Cold,, Any Ideas, Hope I Havent Bought A Duff One.
Could be a problem with:
1.Fuel Filter
2.Spark Plugs - Leads or Dizzy cap and rotor arm.
3.Gearbox - Clutch Problem.
4.Accelerator Cable sticking (REALLY BAD)
But that's about all i can think of too be onist does sound like a fueling problem happend to my dad's volvo....
Check the above and you should find your problem....
Dan
mgf
where to buy leads
Hi Thanks For That Where Is The Best Place To Buy Leads , Rotor Arm Ect From
Sounds like my problem, whcih seems to be the crank shaft position sensor. you may want to phone around and see who can do a code read of the ECU the cheapest (some will do it for 20 pounds, MGR likely to be around 60, some will do it free). Takes a couple of minutes and will let you know if its anyhting like any of the sensors etc.
1 - 5 of 5 Posts
