1 - 8 of 8 Posts
Does anyone know the best solution for this problem on MGF? I understand it is a common trait of the (basically) Honda gearbox. Can new detent be fitted? Or does it need a new 'box?
Brian
Brian
Never heard of this TBH.... The PG1 gearbox gives very few problems as a rule..
The Gearbox mechanism in the `F` is cable operated so I would think its more to do with adjustment than a problem with the gearbox itself!.
Perhaps one of the 2 cables has worked loose and is not fully engaging fifth.......... hence the reason it jumps out!!..
I have had it happen to me once before on a PG1 gearbox.
But it happened because the oil drainer plug had worked loose and the oil had drained out (very noisy gearbox).
so oil level check a good idea.
Although it is most likely cable adjustment that is required.
Hi
It's been happening on mine for the last two years. I did talk to a gearbox specialist he said it may be the linkage, never really got around to getting it fixed. Never throght of the oil??
I do remember some reports some time ago & I think it also happens on the Landrovers as well, same box I think.
MikeS
1 - 8 of 8 Posts
