My MGF drains it's battery such that it won't start. I have a 20W big solar panel and charge controlller fitted to my car which sort of solves/masks the problem.
I would like to find the root cause of the problem this is my thinking so far.
No bonnet light fitted.
Boot light works OK
Mirror lights off.
ECU fittted with LED on engine power circuit which shows power shuts off as it should after 8mins.
Replaced Alternator diode pack
Battery earth good.
Engine earth good.
Radio back up power disconnected- no change
Charging voltage seen on ODB2 as good.
Only things left on are petrol gauge, alarm.
I hear that the alarm system includes a Ni-Cad battery so it keeps sounding even when the main battery is disconnected. Well it makes purfect sence that this battery could be worn out and causing the discharging problem. Where do I find the thing? I wish to remove this extra battery or maybe replace it with a newer one.
Boot light works OK
Mirror lights off.
Battery earth good.
Engine earth good.
