Hi all, after reading a few threads I decided to ask again and I have to apologise in advance as I realise that this issue must be common to these cars and was discussed here many times.
A few notes: I live in Thailand so the temperatures here are extreme as compared to Europe and England. Worst case scenario is 25 celsius at 5 AM. The problem occurs only on really hot days, while on cool ones (about 30 and lower) it doesn't or is not as frequent.
The problem is: as soon as the engine gets hot it starts to stutter as if was an ignition misfire or a fuel supply problem. It happens only within 2000 - 3000 RPM range. If I push the engine above 3000 it works okay but that is not the range of RPM the car wants to work normally. It never stalls though, I can always get from A to B.
Once I saw the check engine yellow light blinking on my dash which went out quickly.
Engine starts normally.
Please direct me what issue should I address and what to tell my dealer to do (imagine the translation problems as I am not a native English speaker and most of the technicians here speak only basic English).
Thank you in advance and my apologies again for bothering the community with silly questions.
