mg zr boot light
i seem to have a problem with my light in the boot it dosent come on dont seem to have any power there bulb is ok carnt find the fuse
anyone help
mg_6_gt
On my 25, the leads to the actual light had fell off, hence the light did not work.
Have a look just by the Right Hand rear speaker and see if there are any wires hanging loose.
I had this problem when i bought my ZR, boot light wasn't coming on so I pulled the light out of the fitting and low and behold one wire had worked itself loose of the connection.
HTH
G
The wires can't work loose as they have an internal metal spring clip (right inside the black connector) which drops into the hole in the bit that sticks out. Many dealers disconnect the lights and fail to push them properly back on.
