1 - 11 of 11 Posts
Hi all
I have recently acquired a 2005 Rover MG ZR and have an intermittent problem with starting it. Sometimes it will start immediately but most of the time when I turn the key to the start position, nothing happens. I have to retry four or five times before it eventually starts.
I thought maybe it is a problem with the immobiliser - Is there any way of knowing whether or not the engine is currently immobilised? The manual states that it will not work correctly if both key fobs are in the car at the same time so I have left one of these in the house but I get the same problem with either key. I have also tried replacing the battery in the key fob but this has made no difference.
Any thoughts ??
Regards
Mark
I think think this is common to the ZR's with the new type fob. I know a few who have this problem. It is the passive immobilser not disarming.
It does it on my OH's brothers ZR too.
ZR starting problem
Thanks for the reply. Do you know whether it is possible to do anything about it or is this something I will have to live with. If so, any tips for starting the car? It's embarrassing when it stalls and I can't get it started.
Regards
Mark
It may be the sender wire to the starter motor. Its red, and its the thinner one of the two. try removing it, cleaning up the terminals with some wire wool/sand paper and put it back.
This has also been a know cause of this problem. It happens on my mums ZR too.
Craig
ZR Starting problems
No, it doesn't beep. In fact it doesn't seem to do anything at all. It sometimes corrects the problem if I lock and then unlock the car but not always.
ZR Starting problem
...I'm still trying to work out whether this is a problem with the immobiliser. Am I correct in thinking that if the Alarm LED has stopped flashing, the immobiliser has been deactivated? Also, for five minutes or so after attempting to start the car, there is a high frequency but low volume (it's barely audible and you can't hear it if the bonnet is down) tone coming from the centre of the engine. Could this be related?
Craig's suggestion of a bad connection on the starter motor also sounds plausible. At the risk of sounding a bit thick, where is the starter motor ??
Regards
Mark
Discussion Starter · #9 ·
ZR starting problem
I haven't needed to try bump starting it because it normally starts after half a dozen or so attempts. I can give it a go though if that would help diagnose the problem. If it bump starts but doesn't start with the key, would that rule out a problem with the immobiliser??
Yes.
If it bump starts, its more than likely going to be an issue with the starter motor, or more so that red wire to the starter.
Craig
mg_zr
starter
there is a large spade type connection to the starter that has a plastic shield around it. They are cr*p and come loose. it most likely 'wiggles about'. take it off, tweak with some pliers and put it back on, it should be tight and your car should start. This problem is the only thing thats ever stopped my 160 starting.
1 - 11 of 11 Posts
