MG ZR/Rover 25 Bits & Fusion Headunit
2732 Views 12 Replies 3 Participants Last post by  ryanj
3
Full MG ZR suspension kit which will lower the standard Rover 25 20mm and make it alot more stiff and give it better handling, this kit is in mint condition, just a bit of paint chiping of as usual.
£70 pickup, or arrange your own courier to pick them up
MG ZR / Rover 25 Tinted Rear Lights, Mint Condition, fits straight into your existing bulbs
SOLD!
Fusion CA-CD500 Headunit Mint Condition SOLD!
CD Tuner made for the world market with rear USB connection for iPod use and control. Two rotary controls, one with joystick function, give you full access to iPod via all the normal Artist, Play list, Genre, Song etc routes. Supplied with iPod connection lead and remote control (although the sample unit had no remote present) and two plug assemblies. One is the unit-to-ISO lead assembly and the other bears a collection of RCA plugs. There are stereo front and rear and a mono subwoofer output as well as a stereo Aux input and another stereo input marked ‘XM’ although the unit is a UK sold item. (Hence one world-market specification.) The front is motorised and has a blue scale monochrome OLED dot display with animations and a full HMI display system to take you through all the possible adjustments. The unit has SRS sound shaping and a set of highpass and lowpass filters as well a subwoofer crossover that can be set in notches as per the spec below. A built in equaliser has three customisable user presets as well as its own selection.
- 4 x 50w (MOSFET Power IC)
- Motorised three-step removable faceplate with hard case
- Full Dot Organic Electro-Luminescent display (OLED)
- iPod USB Direct Connection with supplied cable
- Control via rotary and rotary/joystick
- CD/CD-R/CD-RW/MP3, WMA, AAC, OGG playback
- Electronic skip protection
- Low pass (80Hz/120Hz/160Hz) and High pass filter (90Hz/135Hz/180Hz/215Hz) and subwoofer control
- Bass, Mid & Treble controls
- Seven band EQ with fourteen presets; eleven factory and three customisable
- SRS Wow sound shaping
- Security code
- White or Blue button illumination
- AM/FM Tuner
- Wireless remote control supplied
- Signal to Noise Ratio and Dynamic range not quoted
***RCA Cables & Remote Control Not Included but im sure you can easily get them from somewhere***
***Fusion Headunit, detachable face, ipod connecter and wires to connect to car included in this sale!!***
1 - 13 of 13 Posts
bump priced now lowered!
Pickup from where? :)
Hi I'm based in Rugby cv22 7ah
The fusion headunit is in perfect condition that comes with the iPod/iPhone connector to play great quality music and headunit control
Suspension and rear lights still up for sale
rear lights now sold, only suspension left bump!
1 - 13 of 13 Posts
