Hi guys, I've got a 1.4 ZR and my mum's '98 Freelander 1 needs a new front right caliper. It's got 262mm solid discs which is the same as my ZR so I'm wondering if the calipers are the same too? If they are then I can use the caliper off the ZR to fix the freelander as I was planning on going to a 160 setup on mine anyway. Does anyone know if this would work or not? Thanks
Check the part numbers but from memory the freelander is 5 stud and the ZR 4 which means the disc certainly won't fit.
