mg zr engine cut out
11K views 20 replies 11 participants last post by  matrix MG
hi
my mg zr starts and runs perfect and after running for a while then cuts out after 1-15 minutes starts and may go up to 50miles and happens again, i have spark when she will not start but no petrol changed pump and relay still the same. has any body got any ideas
thanks in advance sam
how many miles it done?
it is recommended to change the fuel filter after 60,000. (not necessary, but i'm trying to rule things out)
are you able to drop the cat and check it's condition? i think someone on here had similar problem, was a collapsed cat blocking the exhaust. (helps to know a friendly mechanic)
Was there anything wrong with the old pump and/or relay?
Call me daft but in the motor trade we like to find what the problem is before fitting expensive parts :eek:mg:
Can you hear the pump running? Is there definitely fuel in the tank (could be faulty fuel gauge)?
Try bridging the relay and see if it runs (if it is a four-pin relay, pins 30 and 87) If not, check for power to the relay (12V and pin 30). If it does, check that the relay is being switched on by the ECU (you should have a PD of 12V across pins 85 and 86).
There's an inertia cut off switch which could be causing the problem. There's a reset button by the brake servo.
#14 ·
Hi, i have a similar problem with my mg but mine cuts out within the first 15 seconds when the engine is cold. What is the inertia cut off switch?
got the parts of a good car swaped them temp. still stopped
definitly has petrol this is a problem over a few weeks
car will drive then stop on the side of the road
intermitent problem drove 15 miles yesterday then stopped then 4 times
the next 15
Have you got dirt floating around in the petrol tank causing the pickup pipe to block, I had this on an old SD1 rover, gave the feeling of no petrol getting through, the only problem is that on the r25 you have to drop the tank to check, alternatively carry a few spanners and when it happens, disconnect the fuel pipe on the inlet side on the filter and turn on the ignition and see if the fuel comes out.
