1 - 8 of 8 Posts
My ZR had been having 'seizures' whereby when driving along in 3rd/4th gear say, the engine started to shake (quite dramatically) and it almost felt like it was going to cut out. It happened for a few minutes, I changed gear (either up or down) and then it stopped.
It only happened a handful of times in the last couple of weeks but then my Mum borrowed it last week and it died on her. It started chugging/engine shaking and then it just cut out, completely. She got it moved over to the side of the road, tried to turn it over, and nothing. It's not the battery as all the dash lights came on and two guys even tried to jump start it but that didn't work.
Has anyone got any ideas as to what direction I should point a mechanic into??! Does it sound like a complete engine seizure, and if so, why??!!
Any ideas would be gratefully received. Thanks.
by nothing do we mean no turning over or nothing at all?
with the ignition on position 2 is there a buzzing noise from the fuel pump?
Is there a clicking noise when you try to start the car?
As AndBurG said, and also, are the battery connections tight, i.e. can you move them easily by hand. It could also be a broken or loose earth connection (big flat steel rope bolted under the bonnet somewhere) , but I would expect other bits to play up as well. If everything else works properly, like wipers/lights/windows/central locking etc. etc. then an earth is less likely to be the cause.
rover_25
starting
why would you get a buzzing from the fuel pump when the ignition is turned on, since its a diesel pump and it is belt driven and not electric??
There is a buzz from the diesel engine, its not the fuel pump as far as I'm aware but someone else will be along to answer that one. If you can't hear the buzz it could be a power problem, it could be a dodgy fuse that has been going intermittantly and has now gone properly.
Discussion Starter #7
By nothing, I mean absolutely nothing at all, just one click and then a kind of one second 'kerdunk' from the engine, then nothing.
no, no buzzing noise from the fuel pump and yes, there is a clicking noise when I try to start the car (as above)
thanks.
I think your battery has suddenly died - for me the "kerdunk" was the give away, so it seems it can't handle any load being taken from it.
Could you try another battery?
1 - 8 of 8 Posts
