Hi all,
Thanks for reading my post.
I am in the process of fixing up a 2002 MG TF and have encountered numerous problems as I am sure you all have. This post concerns the wheels required for the bigger brake kit. There are numerous other problems I am having which will be put in other posts.
The car I purchased had limited edition 16 inch alloys fitted, although I am not sure if they were from an MG F or TF
They are nice alloys though
And after discovering the brakes needed replacing I decided to opt for the upgraded AP 2-pot callipers with bigger discs. After reading numerous reviews and learning they were quite straight forward to fit I decided to fit them myself.
All went well until I went to put the wheels back on. And that didn't work.
For some reason the driver's side was just about ok. The gap between the wheel and the calliper was about a millionth of a mm. But the passenger's side was not happy.
Anyway, I decided that enough rotations of the wheel would grind down the wheel and the calliper to the extent that the wheel would rotate freely so i did this. So my nice brand new shiny red callipers are now very silver on the edges. But it worked and the wheel now spins. Didn't feel great at the time though.
But that wasn't the problem. the problem is the brake hose. The current set up has caused the original brake hoses to wear against the rear of the brake hub causing them to fail and spill brake fluid everywhere, which isn't good if you decide that brakes are useful. That was a scary moment.
So my question is what brake hoses should I replace the original ones with as it will ultimately happen again?
Also, I have decided to purchase replacement wheels because 16inch wheels are useless with thise callipers. But the ones I have got won't fit because MG decided to use a stupid measurement with their 4 stud wheels. So I have these lovely 17 inch black gloss wheels which won't fit. Grrrrrrrrrrrrrrrrr!!!!!!!!!!!!!!!!!!!!
I can purchase hub adapters from Mike Satur for £150 but wanted to know if anybody has tried these andwhat they think. The car only cost me 600 quid so I dont want to spend millions on wheels if I can help it
So opinions on brake hoses, hub adapters the 2-pot AP callpers please
