It would help if you could give a little more info??.... ie is the bonnet pull working the release mechanism (ie bonnet will open but you have to lift it yourself instead of it `popping` up)oceanmatt said:I just bought an 03 TF. The bonnet release in the boot is not opening the bonnet.
Is there any quick fix?
Anything would be appreciated.
You cant open the bonnet from under the car on the TF as they have a guard around the bonnet release mechanism, to stop people from stealing the carhughf said:This happened on my old MGF. Took the garage about 5 minutes to fix. Open the bonnet somehow from under the car then retentioned the cable. I assume the cable had come out or the fixing screw was loose. Never happened again.
