1 - 20 of 127 Posts
· Registered
Morning,I`ve just bought an MG F .The bodywork is excellent to rust ,also the interior is very good The car has only covered 63k However the starter is faulty,just clicking noise from the solenoid I know it isn`t the easiest of jobs,but how do I go about replacing it Len
· Registered
Hi what year is it? There was a recent thread about this, but firstly check that all the leads are tight, and contacts clean.
· Registered
The other thread is here, take a look as there are some pics at post #4 showing the spade connector (starter trigger wire in the pic) which in my case was loose:
Starting/turn over issues - advice and guidance sought
Side note - I have a spare brand new starter motor I bought but didn't need lol, if it fits yours happy to sell it to you for a discount :)
Thanks for the offer Ill let you know how II get on. I have a problem with the rear wheel The tyre is flat and the wheel nots have been put on by a Gorilla Ive noticed,that on two of the nuts there are chrome caps These seem to be a loose fit but I cant remove them Should they come off,to get to the nut also is it a 17mm I think the tyre has a puncture so it has to come off Len
PS how much do you want for the starter
· Registered
Hi the wheel nut caps are always a bit loose but are only removable on the locking nuts. They are terrible things, so change them for solids when you get the chance. (they are available on eBay) Good luck. D4KGP.
· Registered
2002 MG TF VE51FTF
A D4KGP says the std nuts are crap, if you check the wheel brace bag you may have what looks like a piece of plastic tube this is to remove the locking nut cover, if it's missing improvise!!. The nuts are 17mm but if any of the caps are missing you will need a smaller socket to fit.
Remember they are called quick fit fitters cos it takes them secs to do the nut up, but you mins, hours or days to undo.
· Registered
Other tyre and exhaust’ centres are available, but most seem to share similar working practices 😂😂👍
· Registered
Discussion Starter · #10 ·
Hello I managed to prise the caps after a lot of tr
Morning someone mentioned the name of a car insurer,but I am unable to find it on the forum emails
· Registered
Discussion Starter · #11 ·
I forgot to ask what size socket fits over the chrome nut covers Ive managed to prize them off the one wheel ,before removing the nuts Also it looks like black leather on the seats,but when I try to register the car,there are just a load of codes,for the seat types
· Registered
Discussion Starter · #12 ·
I ve just managed to remove the other rear wheel .This was to check how free they are and not too bad ,they did however use the same Gorilla to tighten them up Ive also ordered a set of new wheel nuts Len
· Registered
I hope that you've ordered the solid type nut sold on ebay by: pe16carparts 08. Not more with the caps. Regards. D4KGP.
· Registered
Discussion Starter · #20 ·
Hi, yes you can buy new elasticated straps on eBay.
[Ive ordered the straps,to cure the sticking roof and with the help of friends managed to push the car into my garage I can now look,to see why the starter doesn`t work However the first job is to remove dozens of LED lights in strips They are round the windscreen all round the parcel shelf and down each side of the centre console Or is this the way MG Fs should be decorated How anyone could drive with dozens of LEDs alight fails me .Just hope then didnt blink as well Sorry for the blurred photo the joy of getting these light free with the car overtook me Len
1 - 20 of 127 Posts
