have a few questions i hope you guys can help me with...
i was having a lot of trouble with squeeling at low revs, so i narrowed it down to the alternator, so i took it off to see if i could identify what was wrong with it. it felt like ther was grit grinding inside it, so i took off the plastic end and sprayed with wd40 for a whole and tryed to work free all the logger, i then greased it up and stuck it back on...
it solved the problem..
BUT when i was puting it back on i sheared what i think was the EARTH off, was this what caused my alternator to melt?
i know using wd40 was probably a bit daft but i have put up with the noise for months now and its really annoying not to mention embarassing...
any how i ran it fine for about 60 miles until tonight when my radio started to flick on and off the my rev counter switched off then my speedo switched off!! so i pulled over and switched the engine off, then when i tryed to restart it was making an immobiliser noise, rappid ticking but no engine turn.
my questions are, 1. what additional dammage could be caused?
2. how much would a scrappies charge for an alternator
3. and what caused it? earth? flammable liquid? both?
4. should a new alternator mend my car?
thanks for reading this marathon post and any help with my problem..
