Nicely done how-to, thanks. I have a few spheres that I am hoping to do this to over the winter and I'll definitely be referring to your proceedure.
That makes perfect sense. Thanks for the clear explanation.Mr Scoop,
I take, and agree with, all of your points.
The rubber membrane on the front springs remained intact through repeated MIG welding processes as I built up a leak-free joint. It was cooled regularly by submerging it in water after every pass and left to cool thoroughly between each weld and grind iteration.
It was then left in a warm cupboard for two weeks to dry out and prevent any water remaining in the Nitrogen side.
If I had gotten past the tacking stage on the rear sphere in the photos I anticipate that I would have filled the sphere with cool water to let it absorb some weld heat, given the proximity to the crimp of the upper and lower section and he membrane itself, and also placed some wet towels on it.
When welding the front spheres you are reasonably well distanced from the crimp.
The tacked sphere from the pictures is available to anyone who wants to pay the postage.
Mr.(Count?) Ax,
The liquid fills the lower portion of the springing unit. The upper part is filled with the nitrogen.
They are isolated from one another by a rubber membrane.
The Nitrogen compresses, whereas the liquid flows with the movement of the suspension arm, and so the gas is what affects the actual springing. Without the gas, and full of liquid, it would not work.
Everything BlackOctagon says is correct. The problem is that after 15 / 20 years, the Nitrogen has started to dissipate from some cars. This leads to the suspension getting stiffer as the Hydrogas is pumped up, (to compensate for lack of Nitrogen), and the compressibilty is lost. Worst case scenario is no Nitrogen left, which would make the cars very uncomfortable and probably hard to handle. As there is no existing way to replenish the Nitrogen, we have to come up with something.Am i missing something here? I thought the spheres were full of fluid rather than nitrogen and part of the process to overhaul the F suspension was to use the hydrolastic vacuum pump to evacuate any gas (air) from the sphere prior to refilling with fluid.
Nigel
