classic_rover
What is the difference with the options such as with NNN100752.
How do you distinguish between the ECU options if the part no is the same?
The only difference that you find would be for vehicles fitted with ABS or not. The 1.4/1.6 and 1.8 are all the same ECU partnumber, they are just supplied the relevent info for the car, so if it a Rover 25, 1.4 plus model then it will have all the relevent information for that vehicle programmed in, including the map.
The ECU doesn't control ABS, as i found out with my R25 tdi.
My old tdi had a re-mapped ecu, and the new R25 didn't, but had ABS.
I swapped the ECU and 5as units over, and the re-mapped ECU in the ABS car worked with no problems. The ABS works.
Skelo
As far as I'm aware the ABS has it's own control unit, not sure how it interfaces with the engine ECU and whether all MEMS ECU's are ABS capable.
