Noticed that coolant is above seam about 1" also when taking off cap no pressure - Help??!!
Tess
Tess
I have removed my cap loads recently and when system is cold, I have never had a pressure release when removing the cap. I assumed this was normal Tess. Can someone confirm this?tess200857 said:Thanks for replies
First thing in the morning The coolant is showing as being about 1" above seam. Take cap off - no pressure and no difference in level. Before I had the work done even first thing and stone cold - if the level looked a bit low - I would take the cap off and would have quite a lot of pressure, you know, bubbling gurgling and the like and the level would often go up to normal.
Broon said:I have removed my cap loads recently and when system is cold, I have never had a pressure release when removing the cap. I assumed this was normal Tess. Can someone confirm this?
I cannot confirm that but repeat my belief based on owning cars for more than 30 years - no heat, no pressure. Very minor hiss when removing cap but nothing like the release of pressure from a system at normal operating temperature.When coolant is cold there is no pressure to release - at least none that I've ever noticed on a fairly long list of cars through the ages.
Thought so, so maybe you have nothing to worry about TessSprinter said:I cannot confirm that but repeat my belief based on owning cars for more than 30 years - no heat, no pressure. Very minor hiss when removing cap but nothing like the release of pressure from a system at normal operating temperature.
The water temp guage gets to "normal" pretty quickly 1-3 miles depending on when the car was last used and outside air temperature.tess200857 said:... BTW - How long do other MGF`s take to get to normal running temperature?......
i never hammer it until the temp gauge is showing the normal running temp? .....
And, should the temp rise much more quickly if you have the heater switched off?
