1 - 1 of 1 Posts
Rover 75 V6 estate / wagon Connoisseur
I've noticed that the left hand rear corner of the driver's seat cushion is lifting up / jiggling a bit around corners, around 5 mm play
I've unbolted the seat to see if there were any loose nuts / screws etc etc but all seems fine / tight
It seems there is now a bit of a gap between the metal seat base and the upper leather seat cushion itself. This does not exist on any other seats / corners
Has anyone pulled a seat apart as I can't work out how the bottom seat cushion is connected the the metal frame (eg no bolts or nuts that I can see / feel)
There seems to be a metal flange (near the 10 in the pic) that could have been bent up a bit over the years causing the gap but it seems unlikely that would be the only thing holding the seat cushion to the frame
Pic of where the gap is
1 - 1 of 1 Posts
