Good luck with the search. As I said, rods were generally only available ready assembled. Don't get tricked into buying 2nd hand ones because the small end eye of the rod will probably be stretched and the pin can then move when the engine runs. New pin should be fitted with the small end heated to the point at which it starts to show the tempering colours. It will all need properly supporting due to the draw angle on the inside of the piston bosses. Used rods can be reclaimed by sleeving or converting to floating pins.
