Hi.
Sometimes after it has rained the headlining on the front drivers corner is wet. I have checked the drainage pipes and they are working fine. So I suspect that it is a leaking sunroof. I have just been looking at the sunroof seals and in places the seal was raised. After pulling part of the seal off the sunroof i found a hell of a lot of rust and removed all the loose pieces of rust.
Will i need a new sunroof or will some silicone sealant do the job?
Thanks in advance.
Thanks in advance.
