1 - 2 of 2 Posts
Dear Gents and Dr.Dave,
Have a slight oil leak from KV6 RH camshaft cover where black vacuum hose emerges on driver side, hose is a bit loose (goes to T-piece under acoustic cover). The hose is one of those with the connectors that you pull hose then withdraw collar.
When I refilled on last oil change, I wasn't convinced I hadn't overfilled despite draining for 30 mins (no rush) and measuring the amount that went in. Can't see any other leaks and I can't seem to get a good oil level which bugs me as well. Also, would a bit of loud pedal cause this or is it just wear and tear of a plastic component?
Evening John, Keep your eye on it for a little while now the collar is fitted. Time did you get back home and all ok mate ?
1 - 2 of 2 Posts
