· Registered
mgf
I only have one key fob for my F 1997 so would like another one to be programmed. Not an easy task around this part of the world because first I have to get a garage with a computer that could read the F.
On the other hand I own two extra fobs that came with the original ECU and immobiliser, however am a bit concerned about the whole process taken by unexperienced hands -what if they spoil the only working fob, could that be possible?
So my question is where I could 'Key Fobs Programming Instructions' to be delivered to the people that will do the job?
Many thanks
Mike
· Registered
The memory is wiped and all keys are then programmed, so yes there is a possibility of losing your working fob. However, if they have the equipment, it's pretty straightforward so I don't think it'd be a problem. The instructions would depend on the kit being used.
The Autodiagnos kit can do it, which was the Volvo OE tool over here and then expanded into all makes- I'm not sure what is the norm in Argentina.
If they've got one of these with Multi-Cartridge 2 and the universal/CAN-1 lead, it'll do it, assuming it's the same software as over here. Other kits can do it, but this one I know for sure does it.
Hope this is of some help :)
· Registered
You can recode with the Pscan diagnostic tool, I bought an extra fob, pscan coded them quickly and easily. Make sure the batteries are good in your fob, My first attempt was disasterous and both fobs were erased, I changed the batteries and went through the set up again and it coded them within 5 minutes. Just follow the on screen instructions
· Registered
Holy Thread Revival Batman! This is 13 years old....Agree though using the pscan is straight forward and a pleasure to use.
