You are probably all aware of the importance of keeping the drain holes unblocked on a 75, particularly the one under the pollen filter. This is where the ECU lives.
Well, my filter was due for a change after two years, so I took the cover off.
When I looked down into the chamber, all appeared initially OK. Then I noticed a small greeny-white thread protuding from the drain hole.
Further investigation revealed this to be a plant shoot starting to grow in the muck which had accumulated in the hole. This muck had built up since the last filter change in late 2004.
One dreads to think of the consequences of that plant's roots binding all that soil into a solid mass! A heavy shower or a car wash could have resulted in a flooded ECU ......
From now on , I will rod that hole at every service!!!
