mgf
Hi,
MGTF, 1.6.
It's very jerky/kangeroo type driving when first driving off, for around 30 seconds. Riding the clutch and persevering for about 30 seconds leads to it clearing up and runs fine from then on. But happens every time. Idles OK.
I have changed the coolant temp ECU sensor, no different. Changed the accelerator cable as that was stiff. This improved the throttle response but the initial jerkiness remains. Coolant level doesn't seem to be dropping. Anything else I can try next?
1) Throttle position sensor reset?
2) Throttle body quadrant lubrication?
3) What condition is your air filter in?
4) When were the spark plug leads last changed?
5) When were the spark plugs themselves last changed?
  • Like
Reactions: D4KGP
