1 - 5 of 5 Posts
Discussion Starter · #2 ·
BTTT with pics
JBL Amp
JBL Sub
Also have a 1 farad power cap which ill throw in with jbl amp/sub as dont know if working, couldnt figure out how to wire it up.
Also have an SPLX 4 chwnnel (300w) AMP wanting £20
Here are the specs.....
JBL GTO 75.2 Amplifier
97 Watts RMS x 2 channels at 4 ohms and ≤ 1% THD + N
Signal-to-noise ratio: 82dBA (reference 1 watt into 4 ohms)
145 Watts RMS x 2 channels at 2 ohms, 14.4V supply and ≤ 1% THD + N
290 Watts RMS x 1 channel at 4 ohms, 14.4V supply and ≤ 1% THD + N
Dynamic power: 190 watts at 2 ohms
Effective damping factor: 6.39 at 4 ohms
Frequency response: 10Hz – 90kHz (–3dB)
Maximum input signal: 5.5V
Maximum sensitivity: 230mV
Output regulation: .098dB at 4 ohms
12dB Built-in, variable, low-pass electronic crossover
One pair full-range preamp outputs
Separate high-level and low-level inputs
Dimensions (L x W x H): 295mm x 313mm x 60mm
JBL GTO 1202D Subwoofer
Diameter: 12"
Power Handling, RMS: 300 Watts
Power Handling, Peak: 1200 Watts
Sensitivity: 93dB
Impedance: 1 or 4 Ohms depending on wiring
Mounting Depth: 5-1/16"
Cut-Out Diameter: 11-3/16"
rover_200_coupe
Just to say I own the same sub and amp (JBL) and I highly recomend them! Sound quality is good, and the bass is powerful, but not over powering, I'm into everything, and this set up (after a bit of fiddling) works just as well with dance crap as it does with classical and melow music.
1 - 5 of 5 Posts
