1 - 8 of 8 Posts
Will an ITG maxogen for a zs 180 fit a VVC engine (VI, ZR160)
with or without modification
plz dont post if u r unsure as ure answers will effect weather i buy it
thanks
I have a Pipercross Viper from a ZS180 on my car. You have to saw a bit of the pipe to make it fit (the ZS180 has an extra small tube attached to the filter as well and the filter has a 90 degrees angle), but it does fit.
So I'm pretty sure you can make a Maxogen fit as well, but not without some slight modification.
hmm i thought that the itg maxogen was quite big with a complex intake system requiring some room. anybody got some pics
tada:
You can see the angle and the extra tube in the pic. You can't use the silicon hose, but if you have a Samco hose or something, I'm sure you can make it fit.
hmm ive already got a 90 degree sf silocone elbow for my pipercross vector, however not sure of the fitment for the zs is the same as on the silicone elbow looks smaller
All you have to know is the diameter of the silicon hose. If it's about the same as the one you have (70 mm), it will fit.
1 - 8 of 8 Posts
