1 - 9 of 9 Posts
Today i had the chance to take the intercooler off and give it a good clean, but when removing the pipe work i noticed alot of oil/ gunk in the pipes going to the intake manifold and coming from the turbo. Is this normal as when i had the pipes diconected thye were dripping oil hhhhmmmm io hope nothing has went pop.
Anyway i have included some photies of the pipes and also from around the turbo, Not sure if all the crap around the turbo is just general build up or if it has got a leak.
So anyone got any ideas
cheers
i believe the 45 setup is the opposite to the rest, if i can remeber right. the 25's air goes from top to bottom of the ic, and the 45's are the opposite.
Discussion Starter · #9 ·
The zr/25 air flow goes from top to bottom, which you would think most would go since cold air drops, would seem a bit stupid to go the other way round.
1 - 9 of 9 Posts
