1 - 5 of 5 Posts
Hi, I own a v reg rover 75 cdt, a few days ago i started noticing marks on the pavement where the car had been parked, they were on the drivers side jsut behid the front wheel. On closer inspection is seemed like it was oil and water and I could also see a drip on the bottom of the car.
I checked the oil disptick, it was fine, I checked the oil cap and this too was fine. I then checked the coolant lid and it was covered ina grey gunk, there was also no water in the tank just more gunk. I am confused as tyhe car has performed fine, no overheating I only noticed a problem from the marks left on the pavement......
Help!
Administrator
I reckon it could well be a diesel leak from the fuel rail/injector area. Have seen that on many Freelander TD4's....
Be careful when working on the diesel system, the pressures are very high and the fuel will penetrate your skin causing blood poisoning.
Discussion Starter #5
its leaking from drivers side, thought it was oil at first - its leaking now and I havnet been in the car since 5.30!
1 - 5 of 5 Posts
