Hi all wiper settings work other than intermitant? Any ideas? Also would this be an mot failure?
Just out of curiosity, how much time (ballpark) did it take you? If you did it intermittently among several days what would be the total hours?As above, but you could try taking the motor apart to see if you can clean it up first, I had one of mine not working on intermittent, took motor apart, there was water inside and rust, cleaned it up rebuilt it put it back together and all worked fine...had another which I took apart, cleaned but didn't make any difference was still dead
Motor is simple enough to remove, just undo the linkage nut to the motor, from memory I think its a 15mm spanner and then use a 10mm spanner on the framework/motor bolts to remove it. there are two cross point head screws/bolts holding the bottom casing to the top, undo them and pull apart to clean, it can be surprising how much crud and water gets inside. Or you could leave in place and just undo the two cross head screws/bolts holding lower casing in place and try cleaning it that way without fully dismantling. Time wise, its not that long, less than an hour perhaps depeing on which way you decide to progressJust out of curiosity, how much time (ballpark) did it take you? If you did it intermittently among several days what would be the total hours?
