1 - 2 of 2 Posts
Hi all, I have a 98 MGF VVC and I took the door card off to fix the driver's window but I pressed the sill lock (I believe it's called) in the door a few times in putting the door card back on and didn't disconnect the battery when I was doing it as I didn't think there'd be an issue. Now my interior lights don't come on when I open my doors or when I turn the engine off with the headlights on, but when I have my headlights on and the car off and open a door, the warning still sounds for that. Also, I can switch the mirror light on manually. Every time a problem ends another one begins! Any help appreciated!
A weird problem. Starting with the easy things first: have you checked/tested all fuses?
1 - 2 of 2 Posts
