1 - 12 of 12 Posts
Is my engine mount knackered? & while you're having a look name the unlabeled parts to educate me.
The pictures were taken behind the left front wheel. I've been hearing a 'clanging' from this area when driving over certain bumps & plus when my revs drop from around 3,000 rpm I heard a popping/knocking sort of noise.
Also note how the rubber has curled up off the spring - but I doubt that's the source of my problem.
Looks to me from the pic that you have a broken spring !!!
Looks just like mine when it went about 6 weeks ago.
Urgent attention required if it is.
Ah the bigger picture is much better.
I looked at the coil above the bottom one and it seemed to me that the coating of the spring had split which is usually a sign that the metal underneath could be or is about to fracture.
The picture is still not that clear. Can you clean the coil a bit and take another pic ??
Ok no probs. Make sure you note whats on the sticker if you remove it. You never know you might need it if you need a new spring.
If its only the one side.Have a look the other side,see if you can see anything different.Get someone to push the front down while you look/listen.
Looks a lot better cleaned up and I think panic over.
If you cant see or feel any breaks in the covering then I think you have checked as far as you can and should be ok.
Sorry if I worried you but there have been a few cases of springs breaking recently, including mine, and since I have never had a spring break on any other car in 40 years of motoring makes me a bit cautious.
Discussion Starter · #10 ·
No worries. I'm grateful for any free advice I can get.
Early Rover 75s had a recall for some defect which caused the front springs to break IIRC.
They had two recalls.
The first was for inspection and replace springs if necessary. Vin numbers from RJ001242 to RJ133299 Build dates from 01/12/1998 to 27/10/1999
The Second was to fit a retaining device so that if the spring did fracture it would not destroy the tyre as the same time. Vin number from RJ133300 to RJ247257 Build dates from 27/10/1999 to 20/02/2002
If you follow this link and do a search on Rover 75 from 1998 to date the above info falls out.
http://www.vosa.gov.uk/vosa/apps/recalls/searches/search.asp
Only problem is that cars outside the VIN numbers above are suffering from fratured springs. Mind you I am only basing this on a few cases reported on this forum and The 75 and ZT Owners club forum and you could expect to hear mainly problems on thses sites. Not many people post with a 'my car is great and there is nothing wrong with it' probably cos it would tempt fate a bit
Discussion Starter · #12 ·
I got my flatmate to push the front while I listened but we were unsuccessful. Perhaps if he had a muscle arm like yours...
I'm posting in this thread again primarily to get it to the top of the list.
1 - 12 of 12 Posts
