indicator problems
658 Views 2 Replies 3 Participants Last post by  technozen
have been struggling with intermittant indicators
checked all wires and earths belive may be body control unit
if i change this part do i need to have it programmed to the car
does it control the indicators?
got heater problem as well but have found suitable threads thanks
What Year and type is your ZR ???
Is it the Facelifted Mk2 ??
On the Mk1 the Hazard Switch contols some aspects of the system, plus a faulty realay is worth a look !!!
The BCU creates a flash signal that drives two external relays.
Yes, it will need to be installed with diagnostic equipment plus you will also need new fobs... expensive.
