rover_200_89_95
Hi guys, I own a 93' Rover 214 GSi and I would like to improve it's braking capabilities, as I notice that I need to step on the brakes a lot sooner and harder than in any other car I've driven and it's probably the only thing I'm dissatisfied with in my car.
I've read online that I could adapt the brakes from a newer model but I'd like to have some confirmation before I jump the gun.
The vented discs have a 64mm centering diameter while my smaller full discs have a 61mm centering diameter, will it fit? And can I buy and fit the newer brake caliper without mods?
Thank you.
if this is the case check the brake vacum servo isnt leaking ,
are the breaks solid when you first press them ? .
does the pedal drop slowly if you keep pressure on the pedal while stopped and pressing reasonably hard ?
are any of the calipers seized ?
the breaks on the R8 i had where great when i had it same as or better than the later 400s i drove .
rover_200_89_95
There are no leaks and the pedal drops as intended.
From what I've seen the Rover cars after 95 have the bigger 359mm discs so they should break a lot better.
