1 - 15 of 15 Posts
Hi, I have a problem with the one and only key fob for my mg tf, had to take it apart to fix it.
Is there a go to guy on here to sort out a couple of new fobs and program them to the immobiliser?
Depends where you live if looking for local, and what type of fob, lucas (rectangular) or Pektron (oval) as there is a big difference in the alarm systems and not many keep spare pektron fobs available if they don't recode alarms as a business. Your other option is to look at this site...highly recommended by many on this forum Technozen Electronics - Home Of Pektron SCU Repair
Hi Dert, it's oval so it must be pektron but the car is a 2002?
In the Garage
MG TF
As it is 2002 the fob should be Lucas. However it is possible that a new loom and electrical systems have been put into the car for some reason, I have seen this before.
I've a 1996 F which has an oval fob, appeared some nissans used a lucas alarm system the lucas fob looks like this
The Pektron is this type
In the Garage
MG TF
Yes it is the Lucas one, you may find a local locksmith with the correct equipment to program the new fob or search online for MG or Rover fobs.
@ CaroleJ, Julian mentions using Pscan to program fobs which with the lucas ones is a very easy thing to do. There are some members on this forum who will/may happily program a fob for free, or if they have a spare fob, for the cost of the fob, this is why I mentioned your location as you may be near members who could/would do this. Lucas fobs are easily purchased on ebay, sometimes for under £10 posted, if you go this route just don't purchase a 3TXa as these fobs only work on the early 1995/6 and early 1997 F's. Your other route is as Chris T mentions above.
Discussion Starter · #10 ·
Or by Pscan. I used it recently to program 2 new Lucas fobs (I now have the max 4 fobs programmed to my F). Very easy to do.
Thank you guy's I'm in Boston if anyone local can help but not picking the car up until tomorrow could do with a couple of spar fabs too.
Technozen sorted my Lucas fobs for me last year, turned around in a few days and all working as it should.
I am miles away in Liverpool but a few £ postage had me sorted and had my F back on the road 👍👍👍
mgf
Another vote for Technozen. Posted the 5as unit and 2 Lucas key fobs for programming and all back in a few days. Got the replacment fob from ebay.
MG TF
I'm in Barnsley South Yorkshire and can sort out a fob if you are ever over this way.
Sent from my M2002J9G using Tapatalk
1 - 15 of 15 Posts
