I thought i should make an effort and remove the noisy wiper motor with a new one.
I got one sent over for a reasonably price so nows the time to fit it.
I made a mental note were the linkages were when i un bolted them, then unbolted the wiper bracket bolt holding it to the car.
It came out with out major drama, just a matter of getting it in the right rotation and it comes right out.
The replacement motor was for a TF as the plug was diferent to the OE in the car so i needed to put the old plug wired to the new motor.
All went ok, i tested it befor attempting to reinstall it and it worked ok.
Whisper quiet compared to the old one.
I reinstated it in reverse to how i took it out.
I put the linkage back in the same position ( i think ?) but when i switched it on , ………nothing ?
The motor was getting hot, so i had life that far…
further inspection discovered it was binding in several places, ie each linkage end, and the center pivot behind the motor spline .
Just thinking as i wright this :
1/ should the spline bracket be at 12 o'clock or 6 o'clock or does it even matter ?
is there something so obvious i cant see it,
Any advice gratefully accepted ..
