Hybrid injectors
5.6K views 24 replies 9 participants last post by  Dakta
After taking a little sabbatical to rebuild the race bike (HGF) I'm back to thinking about the MG. I have been thinking about hybrid injectors rather than just going the SDI rout so have been looking at different nozzles. Only I don't have a starting point! I can find out the number and size of the holes in the stock MG injectors.
The info I have so far is:
MGZR = DSLA145P870 2s = 5x0.174 (0.11883)
Freelander L series = DSLA145P682 2s = 5x0.2 (0.157)
SDI = DSLA145P446 2s = 5X0.22 (0.18997)
200TDI = DSLA145P208 2s = 5X0.24 (0.22608)
300TDI = DSLA145P366 2s = 5X0.26 (0.26533)
Other Nozzles:
DSLA145P631 2s = 5X0.21 (0.17309)
DSLA145P631+ 2s = 5X0.215 (0.18143)
DSLA145p882 2s = 6X0.205 (0.19793)
DSLA145p763 cr = 5X0.185 (0.13433)
DSLA145P763+ cr = 5X0.185 (0.13433)
DSLA145P1091 cr = 5X0.2 (0.15700)
DSLA145P626 = 5X0.22 (0.18997)
DSLA145P1097 = 7X0.19 (0.19836)
DSLA145P330 = 5X0.23 (0.20763)
DSLA145P396 = 5X0.23 (0.20763)
DSLA145P462 = 5X0.23 (0.20763)
DSLA145P464 = 5X0.23 (0.20763)
DSLA145P263 = 5x0.245 (0.23559)
DSLA145P463 = 5X0.245 (0.23559)
DSLA145P311M = 6X0.25 (0.29437)
DSLA145P268 = 8x0.22 (0.30395)
DSLA145P300 = 5X0.29 (0.33009)
DSLA145P379 = 8X0.23 (0.33221)
DSLA145P380 = 8X0.23 (0.33221)
DSLA145P269 = 8x0.24 (0.36172)
The first number is the Bosch part number as I understand, the #x0.### is the number and diameter in mm of the holes (I assume) and the third is the area of the holes I have calculated assuming the holes are in mm!! The 2s means 2 spring which I assume means dual stage. and the cr well that is anyone's guess but it was in the catalogue!!
If anyone has the MG injector info that would be great and if the Freelander L series info is out there I would like to add it for completeness.
The other nozzles I have listed were from a catalogue by a company called Seven.
#4 ·
Interesting. I don't have a ZR injector to hand (just left my parents where they are stored!) or i'd check. I'd be interested to know the nozzle diameter on the ZR injector compared to the SDI version.
I've often thought that having a nozzle with 8 holes (as with some of these) but smaller diameter would yield better atomization (retaining good MPG) and also allow for increased fueling (so more power).
I have been looking at the effect of the number of holes on performance and the general rule is:
5 holes for power.
7 holes for clean burn.
I have a pdf of someone study that they did, let me just see if I can find the link....
http://cdn.intechopen.com/pdfs/1134...s/11340/InTech-Effect_of_injector_nozzle_holes_on_diesel_engine_performance.pdf
The study was based on one engine so don't know if it hold true for larger capacity engines? Gets a bit heavy in places but the conclusion is worth a read.
#14 ·
tbh one of the more attractive things is, it's a nice upgrade (I know that from my flow tests) but on the grand scale it's not all that big either. (okay, it's on the big end of the scale, but there's bigger lol)
I have now found the last few bits of data with many thanks going to Bosch Technical for providing the info.
I have put the data in my first post so all the info is in one place!!
The stock injectors are smaller than I was expecting!!
hahaha
would you beleive it i intend to run rather lean for me. Gotta be careful with these vnt's. The 300tdi will probably still be on the larger end of the scale but probably be a little kinder than the wingies. With a rough idea of the flow rates over increasing injection pressure I can probably draw up a rough model that can be used to callibrate things so the ecu don't get too misled when they eventually go in.
Be a while before I play with injectors though, got a lot going on :( just regular sdi's at the minute which actually deliver an allright punch, I'm just wary of the injection period with these - I do have concerns for the high iq's on vp37's it's gunna be too long really bearing in mind we don't really want to touch the timing.
#19 ·
One of the main points to take away from that document:
Furthermore, jets emerging from smaller
nozzle orifices were shown not to penetrate as far as those emerging from larger orifices.
This decrease in penetration means that the fuel will not be exposed to all of the available air
in the chamber.
Which perfectly corresponds with what 220Dratturbo said. Fewer holes = more (possible) power
I assumed that the '2s' meant 2 stage but have no idea what the 'cr' was related to, I was just taking the info straight out of the Seven catalogue.
Common rail does seem like a logical explanation. All the remaining nozzles with no codes I guess are single stage.
fear with me and sdi's is seeing smoke increase with fuelling and thinking it's the turbo not flowing enough when it might not be, it'll be hard to tell, hard to measure unless one does experiments. But at what cost?
We'll have to see I suppose.
