well, mowog73, you have created a new post in one link really.. since the whole original post can be seen... a credit to you.
its not hard to recreate the post, because you have saved the images..
that means they can be recreated , with the text..
like this..
How to replace clutch and flywheel (picture heavy)
https://forums.mg-rover.org/mgf-mgt...ce-clutch-flywheel-picture-heavy-254468/After I tortured myself doing it I thought I post it up here for everyone:the whole thing is based on Dieter’s manual:
http://www.mgfcar.de/gearbox/clutch_replacement_MGF.htmfirst of all I left the car on the ground, didn’t want to break my back so I did everything as far as I could without raising it:First disconnect the battery
then all you need is a secure site that can host the images
i used google for this example. i uploaded the image, to google plus and then put it the https://forums.mg-rover.org/mgf-mgtf-%2Asponsored-mgfntfbitz-mgf-mg-tf-parts-01457-238202%2A-12/how-replace-clutch-flywheel-picture-heavy-254468/mgf-mgtf-%2Asponsored-mgfntfbitz-mgf-mg-tf-parts-01457-238202%2A-12/how-replace-clutch-flywheel-picture-heavy-254468/ link in this post...
here is the post ive made for example so you can see how i made the picture come back.. "
How to replace clutch and flywheel (picture heavy)[url]https://forums.mg-rover.org/mgf-mgtf-*sponsored-mgfntfbitz-mgf-mg-tf-parts-01457-238202*-12/how-replace-clutch-flywheel-picture-heavy-254468/After[/url] I tortured myself doing it I thought I post it up here for everyone:the whole thing is based on Dieter’s manual: [url]http://www.mgfcar.de/gearbox/clutch_replacement_MGF.htmfirst[/url] of all I left the car on the ground, didn’t want to break my back so I did everything as far as I could without raising it:First disconnect the battery
[url]https://lh3.googleusercontent.com/-RxW9877xDXM/XAmCDM29aLI/AAAAAAAAAUU/9QQkDWcLlocnVqEO48-mBoRdRMbC5AcRgCLcBGAs/w663-h497-n-rw/clutch1.JPG[/url]
i used google for this example. i uploaded the image, to google plus and and then put it the [img] link in this post...
